I have an old Asus mother board, Intel Pentium CPU (2.40GHz), a few gigs of ram .etc and I want to run Mac OSx on it (make it a "Hackintosh"), I wont be putting a heavy load on it just using it for a few light programs. Is it possible?
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/29337-is-this-possible-please-help/
Your motherboard is the essentially the main component that has to be compatible. I tried making a hackintosh out of an old Pentium 4 rig, and it didnt work for me. However, you may have a different experience. I would suggest just to go for it, as I doubt people will reliably be able to say if your system is compatible or not. Go on tonymacx86.com and research some, and then when your ready, try and install mac OSX. The worst case is that it doesnt work, and you just go back to windows.
I was reading and i found that the mobo needs a DSDM File or something and its possible to just make one or find one for your mobo is this true?
You'd probably be better off just running an OS X virtual machine on your current machine.  Trying to get it up and running on that old rig probably won't be fun.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
