I'm trying to get into 3d designing and rendering but I'm not sure which software to use. I'm trying to make it realistic so things such as google sketchup and other similar things are out of the question. So, what software would you suggest? preferably free/30 day demos would be pretty good so i could try it out but paid software is good as well.
Thanks - Harry :)
https://linustechtips.com/topic/293283-cad-software-help/
Before I started doing 3D work seriously, I used blendr a lot.
Blendr is very powerful, and free to use.
Some other good ones are 3DS Max and Autocad which both have educational version for free.
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
https://linustechtips.com/topic/293283-cad-software-help/#findComment-3982285
great, thanks. I'll have a look at this but any more suggestions are great :)
there's also Cinema 4d
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
https://linustechtips.com/topic/293283-cad-software-help/#findComment-3982325
