I am seriously considering building the "Positron" https://www.youtube.com/watch?v=wmuNTpKGOZU, something I saw on Austin Evan's youtube channel. Anyway the specs are as follows:
Intel Core i5-4460
EVGA GTX 970
MSI H97 Guard Pro
8GB Corsair Vengeance RAM
256GB Crucial MX100 SSD
1TB Western Digital Blue Hard Drive
600W Corsair CX600 Power Supply
NZXT S340 Mid-Tower CA-S340W-W1 Case
The only problem I have with this is that I am in need of an Optical Drive. Which drive would you recommend for this build? Obviously I would need a different case to accommodate for the Optical Drive, so I was thinking an NZXT Phantom 240 Mid Tower. Has anyone had any experience with this case, or would any of you suggest a different case. Please keep in mind that this is my first build, and I'm not looking to change any other aspects of this build. Any and all help is greatly appreciated!
https://linustechtips.com/topic/293175-pc-case-help-first-build/
Any old DVD drive would do, and the 240 should be fine. However, you could stick with the s340 if you just got an external one
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3980826
Pls, that build is pure boner.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3980869
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3980934
Wait for broadwell and get that when it comes out. And just get an external dvd drive
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3980950
http://pcpartpicker.com/p/8VXMD3
About 60 dollars more. Comes with better processor, an actual cpu cooler, some fans, better case, a color scheme (if that matters to you)
However I would agree to the above post, broadwell is probably worth waiting for.
My Build: 4690k @ 4.7 GHz, ASUS Strix 970 @ 1316 MHz, H105, Corsair Vengeance Pro @ 1600 MHz, H440, RM750
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3980952
And also, as this build was suggested instead; Intel Core i5-4690K 3.5GHz Quad-Core Processor
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
MSI Z87-GD65 Gaming ATX LGA1150 Motherboard
G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
MSI GeForce GTX 970 4GB Twin Frozr V Video Card
Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case
Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply
Is this build better than the "Positron", or should I just go with the "Positron"?
Thanks heaps in advance!
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3981322
This is better except for no SSD, but get a Z97 board like this one:
http://pcpartpicker.com/part/asrock-motherboard-z97pro4
It won't require a BIOS update.
MSI or EVGA it doesn't matter one has a bit better performance then the other it is what you like and want.
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3981469
So for the motherboard, I'm quite conflicted. Should I get the Z97, the Z87 or the H97? Please keep in mind I don't intend on overclocking! :) Also what brand is best?
MSI mobos are pretty good. Here is a Z97 board I would recommend http://www.newegg.com/Product/Product.aspx?Item=N82E16813130770
Also, the reason you should get Z97 instead of Z87 is because Z87 need a bios update, which is a huge headache to whomever has the misfortune to have to do it.
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3988102
Thanks for the input everyone, but I was wondering should I with the EVGA GTX 970 or the MSI GTX 970? Please tell me why you think this, and I also forgot to add that I don't plan to overclock this.
It is a good build. Either gpu would be good but I would choose the EVGA GTX 970 ACX 2.0 or the Asus Strix GTX 970.
Why is an optical drive needed?
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3988220
My final question (thanks everyone for the help) is this: http://au.pcpartpicker.com/user/warrenpnigel/saved/nbzWGX
Better than the original "Positron" Build. What I'm really asking is if it is worth paying an extra $160 for the first build over the Positron, and will I experience much extra performance-wise. Thanks in advance! :)
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3989178
The cpu cooler will not fit in the case. The cooler is 159mm tall. The case clearance is 158mm. Unless the environment in which the system operates is very warm, the stock cooler will suffice.
Spend less on the motherboard. The savings can go to memory, psu, and cpu.
Get DDR-1600 memory.
Get a modular psu.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($237.00 @ Centre Com)
Motherboard: Asus H97-PLUS ATX LGA1150 Motherboard  ($128.00 @ Centre Com)
Memory: Kingston Fury Red Series 8GB (2 x 4GB) DDR3-1866 Memory  ($99.00 @ Centre Com)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($139.00 @ PLE Computers)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($99.00 @ CPL Online)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($499.00 @ CPL Online)
Case: NZXT Phantom 240 ATX Mid Tower Case  ($89.00 @ CPL Online)
Power Supply: Silverstone Strider 600W 80+ Silver Certified Fully-Modular ATX Power Supply  ($108.00 @ CPL Online)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer  ($21.90 @ Mwave Australia)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($119.00 @ Mwave Australia)
Total: $1538.90
Generated by PCPartPicker 2015-01-20 03:04 EST+1100
https://linustechtips.com/topic/293175-pc-case-help-first-build/#findComment-3992082
