I'm currently having a samsung 850Pro 256GB SSD. the specs. that they mentioned in their web site is 550/520. But, when I benchmarked my ssd it goes around 370/285. help me to solve this problem.
post-185618-0-83847100-1421478786_thumb.
CPU: Intel Core i7 4790K @ 4.8GHz | Cooler: Corsair H100i | MOBO: Asus Maximus VII Formula RAM: Corsair Vengeance Pro 2x 4GB DDR 3 2400MHz SSD: Samsung 850Pro 256GB  HDD: Western digital Caviar blue 1tb OD: Asus X-multi DVD R/W | PSU: Seasonic x850w | GPU: Asus Strix GTX980 | Case: Corsair 760t | Monitor: AOC I2276VM 22" | Soundcard: Asus Xonar Phoebus | Subwoofer: Logitech Z906 | Fans: Corsair SP120 High performance x 4 fans Keyboard: Logitech G19s | Mouse:Logitech G700s | Headset: Asus Cerberus | UPS: Prolink Pro1200SFCU
https://linustechtips.com/topic/292532-samsung-850pro-readwrite-problem/
What is your motherboard?
And are you sure you have plugged it into a SATA 3 port?
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
Asus maximus VII formula. Yep I plugged that in to a SATA 3 port.
On latest firmware?
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
On latest firmware?
As can be seen on the screenhot: yes. ;)
@MaXimum ChaMod
Strange... these speeds really look like SATA 2. Did you connect it via the Intel SATA ports or the AS media ports?
[Main rig "ToXxXiC":]
CPU: Intel Core i7-4790K | MB: ASUS Maximus VII Formula | RAM: G.Skill TridentX 32GB 2400MHz (DDR-3) | GPU: EVGA GTX980 Hydro Copper | Storage: Samsung 850 Pro 256GB SSD + Samsung 850 EVO 1TB SSD (+NAS) | Sound: OnBoard | PSU: XFX Black Edition Pro 1050W 80+ Gold | Case: Cooler Master Cosmos II | Cooling: Full Custom Watercooling Loop (CPU+GPU+MB) | OS: Windows 7 Professional (64-Bit)
Ooops. I'm very robotic with my replies when it comes to this type of problem.
@MaXimum ChaMod
No any firmwares updates for 850Pro. Right? Asmedia
Try again with Intel instead of AS media.
how abt ur R/W speeds? I think u also having a 850Pro.
Still same :( I formatted my PC too. changed the sata port to intel too..
For 500+ speed intel rapid storage or something like that require?
I believe the Intel SATA drivers are part of the Rapid Storage file from ASUS, (even newer version from Intel available) so the answer is probably yes.
