Help With Rig Updates
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  @4.8GHz
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler
Motherboard: ASRock Z97M OC Formula Micro ATX LGA1150 Motherboard
Memory: Kingston Fury White Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI GeForce GTX 770 2GB TWIN FROZR Video Card
Case: Cooler Master N200 MicroATX Mid Tower Case w/500W Power Supply
Few Things
Hard Drive Starting To Fail On Me
H105 Starting to Die Out After 1.5 Years
The Case Is Freaking Straight Up Ugly
The Color Scheme Is Ugly
GTX 770 Alive But,Ugly
The 500W Barely Makes The Cut
To Change (Tell Me What You Think)
I don't need a 2TB HDD so instead going to get a 120GB 840 EVO and 1TB Cavair Blue
New cooler might be Noctua NH-D14 or 100i
For Motherboard I wan't a new one for color scheme reasons, Want a MSI Z97 Krait Edition For The White Color Scheme
For color scheme I can swap my twin frozer for my sister's reference 780 (make her think I have a 970) then paint it white
For Case Wanna get the S340 and For PSU Want Corsair RM650 Full-Modular with some sexy white sleeved cables
As For Ram It's White So Yeah
https://linustechtips.com/topic/292349-help-with-rig-updates/
Double post...
Get a 1TB Seagate Barracuda, only $40 and faster.
The H100i, as it looks cleaner and takes up less space on the mobo.
Huh never used MSI mobos...
Please dont cheat people, its not niiice. Srsly...
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/292349-help-with-rig-updates/#findComment-3970827
Why steal your sisters graphics card and replace it with your 770? Are you Searching for trouble or are you so cheap you would go so low to take your sisters graphics card becouse you dont like the look of your graphics card anymore?
It would be Fraud.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/292349-help-with-rig-updates/#findComment-3970853
It would be Fraud.
Because he's a liar
A few weeks ago he made up stories about his 5930k and three 980's about how they got water damage and how he was going to sell the remaining parts for an AMD rig.
RIP in pepperonis m8s
https://linustechtips.com/topic/292349-help-with-rig-updates/#findComment-3970876
Because he's a liar
Makes sense, Do i have your permission to go get my axe and Fix a few things?
My Gaming PC
https://linustechtips.com/topic/292349-help-with-rig-updates/#findComment-3970913
No offense, but you're an asshole if you plan to steal and swap your 770 for your sister's 780 just for aesthetics.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/292349-help-with-rig-updates/#findComment-3970928
