Hi all, so over the last few days I have noticed ping spikes in source games such as global offensive and tf2. My ping will be fine (around 60ms) but every minute or so there is a spike where it will reach up too 300ms causing me to die. I am fairly certain it is NOT a network issue as this problem does not exist on my laptop with lower specs than my desktop. Does anyone know the problem? I have tried a registry fix, verify game cache and most of the obvious things. The issue only seems to happen on source games, even on community servers.
(SpecsCPU: Intel Core i3-4150 3.5GHz GPU: AMD Radeon HD 7850 MOTHERBOARD: Gigabyte H81M-S2PV RAM: 4GB Storage: 2TB WD HDD
(Peripherals) Keyboard: Corsair K95 Mouse: Zowie EC2-A Headset: Audio-Technica ATH-M50X's Microphone: Blue Snowball
https://linustechtips.com/topic/292293-latency-problem-with-source-games/
What servers?
Both Community and Valve servers
Could be a hard drive issue and most likely is
Should I try defragmentation or is it toast?
First related to the servers did you use the same server on both your laptop and pc?If so you had the same spike issues?If you didn't use the same server then everything is fine...if the problems occur on some servers only,again is the sever's fault
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
All server I would join.
Then may be a hard disk issue.Use this or this(or download crystal disk from where ever you please) and post a screen shot here.
Here ya go http://i.imgur.com/l3nxxIy.png?1
Looking normal...maybe some bad sectors.Use this (careful with the install there's a lot of crapware) and check for bad sectors/check disk.After you install it click go to home select the partition your games are on and check disk.If bad sectors are a few to non then is not a disk issue
0 errors. Any other ideas?
One last question.Do you get these skipes in any other games?Beside online.If so tell me which ones if not well maybe a network issue
No I do not. just when Im playing online. If I play even these games offline they are fine.
I had this problem when playing halo reach on my xbox, you need to open ports on your router for that game. Here is a website that will help you with opening the ports on your router for CS:GO.
Depending on your router make sure you open both TCP and UDP and make sure to set your computer to a static IP.
This may help ^^
Not sure though. Seems a bit weird, especially for Source.
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
This may help ^^
Thanks but I've already tried that.
Here is a recording I made. You can see my ping in the bottom, this is the worst it has been. It generally sticks around 60-70ms with spikes. This does not occur on my other computer on the same connection.
https://www.youtube.com/watch?v=95faX4Rry6M
