I upgraded my motherboard a while back and had always used a USB mic so I never encountered this problem. When I plug a pair of headphone into the green 3.5 mm headphone jack on the motherboard, there is no sound. I have uninstalled and re-installed the drivers from the manufacturers website, ensure that the headphones work with other devices, made sure they were enabled in the bios, have them selected as the default, and when I ran the windows audio troubleshooting tool, the result was that the headphones weren't plugged in. I don't know what could be happening. Please help!
https://linustechtips.com/topic/291855-audio-not-working/
so both front and back jacks are not working?
i guess your mobo audio is broken
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/291855-audio-not-working/#findComment-3964067
i'm really hoping that's not the case, but if it is, i still have warranty
some may find it a hassle to send the board for RMA
others may just invest in a USB headset
https://linustechtips.com/topic/291855-audio-not-working/#findComment-3964125
i could get a usb dac, was thinking about it anyway
Did you check the ports on the back of the PC?
Also, if you want to invest in a USB dac and amp, I would strongly suggest the Schiit Stack.
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/291855-audio-not-working/#findComment-3965099
