First Build
Go to solution Solved by pinksnowmanshandle,
Yeah, definitely not fitting the budget. Do you know what kind of I5 or 7 that can get decent editing performance?
I made an X99 build that was cheaper than the X79 build.
Though if you want something different or you want it to be more extravagant, X99 is out of the question for your budget the best current Z97 (Haswell/Devils Canyon i5 and i7 are:)
i5 4690K
i7 4790K
 Though Intel is close to releasing Broadwell-K CPUs.
I've been wanting to move from console to PC for a while now. For my first build I used these parts:
CPU: AMD FX-8350 4.0GHz 8-Core Processor
CPU Cooler: NZXT Kraken X31 69.5 CFM Liquid CPU Cooler
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard
RAM: Corsair Vengeance 16GB (4 x 4GB) DDR3-2133 Memory
Storage: Kingston SSDNow V300 Series 480GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
GPU: MSI GeForce GTX 970 4GB Twin Frozr V Video Card
Case: NZXT Phantom 410 (Black/Orange) ATX Mid Tower Case
PSU: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX
Optical Drive: Asus DRW-24F1ST DVD/CD Writer
OS: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)
Fans: NZXT Air Flow Series 59.1 CFM 120mm Fan Red LED
NZXT Air Flow Series 83.6 CFM 140mm Fan Red LED
I would really like some feedback and tips and such so that I can get the best gaming and browsing experience I can get.
This is the fan setup I will try and use.
Sorry about the low res:p
Green= GPU
https://linustechtips.com/topic/291822-first-build/
Green= GPU
what is your entire budget ? it seem well but go with intel its much more powerful
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/291822-first-build/#findComment-3963713
snip
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($139.95 @ SuperBiiz)
Motherboard: ASRock FM2A88M EXTREME4+ Micro ATX FM2+ Motherboard  ($74.99 @ SuperBiiz)
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Drive  ($53.99 @ NCIX US)
Video Card: PowerColor Radeon R7 250 1GB Video Card  ($87.99 @ SuperBiiz)
Case: be quiet! Silent Base 800 ATX Mid Tower Case  ($119.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $933.72
Generated by PCPartPicker 2015-01-16 00:29 EST-0500
-or-
CPU: Intel Core i7-4930K 3.4GHz 6-Core Processor  ($554.99 @ NCIX US)
Motherboard: ASRock X79 Extreme4 ATX LGA2011 Motherboard  ($198.90 @ SuperBiiz)
Case: BitFenix Shadow ATX Mid Tower Case  ($78.99 @ SuperBiiz)
Total: $1583.67
Generated by PCPartPicker 2015-01-16 00:34 EST-0500
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/291822-first-build/#findComment-3963820
that amd cpu is only useful for very heavily threaded applications, so if this is just a normal casual gaming PC, intel i5 would be better
it's exactly what I need, just worried about the chipset. Intel I know doesn't perform as well with editing, but than again, my min porpoise is to play games at max 1080p.
https://linustechtips.com/topic/291822-first-build/#findComment-3963840
X99 is good for content creation that's what I plan on building my first and future build on. , but it would be really hard to get X99 on your budget.
Or maybe not...
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($299.99 @ Micro Center)
Motherboard: ASRock X99 Extreme3 ATX LGA2011-3 Motherboard  ($175.78 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($129.98 @ OutletPC)
Video Card: PNY GeForce GTX 970 4GB XLR8 Video Card  ($329.00 @ Amazon)
Total: $1483.53
Generated by PCPartPicker 2015-01-16 00:43 EST-0500
https://linustechtips.com/topic/291822-first-build/#findComment-3963859
X99 is good for content creation that's what I plan on building my first and future build on but it would be really hard to get X99 on your budget.
Well, seems like everyone's suggesting Intel. Which one should I get?
https://linustechtips.com/topic/291822-first-build/#findComment-3963900
i5 4690K
i7 4790K
https://linustechtips.com/topic/291822-first-build/#findComment-3963918
i5 4690K
i7 4790K
i5 4690K
i7 4790K
I think I'm going to wait for the broadwell-k's. I'm moving soon anyway, and I'd rather wait to get some better gaming and editing performance. That and gta 5 pc comes out:)
Thanks a lot!
BTW, changing the ssd to Samsung evo 500 GBP.
https://linustechtips.com/topic/291822-first-build/#findComment-3963939
Total: $933.72
-or-
Total: $1583.67
Y not 5820K?
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/291822-first-build/#findComment-3968905
Y not 5820K?
Well I did modify the AMD and X79 build to a X99 build that wasn't as extravagant as a Z97 Haswell/Devils Canyon (K) or Broadwell-K build could be and only because DDR4 and X99 mobos cost more than Z97 Mobos and DDR3.
https://linustechtips.com/topic/291822-first-build/#findComment-3968933
True, the mobos arent that bad but the DDR4 is expensive
https://linustechtips.com/topic/291822-first-build/#findComment-3969017
