Hey all.
Today, i went to the store and bought a gtx 970 twin frozr v edition.
When i got home, I went straight to installing it. I took out my old 9600gt without uninstalling the drivers, because i was in such a hurry to try my 970. I installed the 970, and started her up, and i got a screen saying error, there has been a hatdware/software change, please put in your win8.1 disk and go to fix my pc. I did this and selected advanced options, then hit automatically fix errors. I restarted the pc, and it worked, aside from the resolution being off a bit, which i fixed immediately. But all of the programs were either missing icons or not on my desktop. I went to "this pc" and checked, and sure enough, there was no 2tb hdd showing. My ssd worked fine, but the hdd, not so much. I went and undid the back panel, and found the sata power came out on the hdd, so i plugged it in, started my pc, and i still have the problem. I tried to partition it, put windows couldnt find the directory for the partition editor. I need help.
I am a beautiful person who is a good idea to have a good time to time and money to buy a new job and I need some help with the same time for the first time in the middle of the day.
https://linustechtips.com/topic/291817-970-problems/
If you right click the Windows icon in the lower left corner and go into Disk Management; does it show your HDD?
1) This is exactly what I would try
2) is this an infiltration of LTT by Tek Syndicate? or am I late to the party noticing this?
I am addicted to building gaming PCs but I don't have a great reason to stop...yet...
https://linustechtips.com/topic/291817-970-problems/#findComment-3964462
alright, so, I reset my computer (via windows install), and I right clicked the windows button, chose disk management, and my hdd wasn't there, soooo... am I SOL?
https://linustechtips.com/topic/291817-970-problems/#findComment-3971490
