Why is power delivery important?
Go to solution Solved by Lays,
Longer lasting components, "cleaner" power, more voltage output whilst being stable, and it's more efficient.
Some people say it doesn't matter, and it doesn't really for the average consumer and 90% of overclockers for the most part.
It does start to matter when you start pushing large voltages through the CPU with custom cooling like custom loops / Ln2/ etc.
I see it on a lot of motherboards and GPUs with varying degrees of marketing fluff about having 10 or 12 phase power delivery, premium alloy chokes, platinum capacitors, etc...
But why is that important?
The only time incorrectly is spelled incorrectly is when it is spelled incorrectly.
https://linustechtips.com/topic/291792-why-is-power-delivery-important/
Better power efficiency, and probably better overclocking.
Cleaner power gives longer lifespan. The reason why having a higher phase count helps is because it allows the current to remain stable, and this helps a lot when you have components pulling a lot of power. The components also are more durable.
OCing and efficiency.
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
