Need suggestions for Custom Loop
Go to solution Solved by airdeano,
Alphacool 360mm Radiator monsta
Xigmatek something fans
XSPC Raystorm CPU Block
EK 7950 Block
Bitspower 150 Reservoir
Swiftech 350 Pump
using stock pump top
Masterkleer Tubing 3/8x1/2
Koolance 3/8x1/2 fittings
Phobya 3/8x1/2 90-Degree Rotary Fitting
Bitspower Mini Valve
looks fine..
airdeano
Parts that I have so far are: Asus Z87 Pro mobo, Intel 4770K, Kingston Hyper X Ram DDR3, XFX 7950 Core Edition, a 630 Watt Power Supply and a Silverstone case that I modded.
The water cooling parts that I am thinking about: Alphacool NexXxoS Monsta Triple 120mm Radiator, Swiftech MCP350 Pump, Koolance 3/8" x 1/2" Compression fittings (black), Bitspower Water Tank Z-Multi 150 Inline Reservoir, Phobya G1/4" Thread 3/8" ID x 1/2" OD 90-Degree Rotary Compression Fitting, Bitspower G1/4" Mini Valve - Matte Black, EK Radeon HD 7950 VGA Liquid Cooling Block, and Masterkleer PVC Tubing 3/8" ID / 1/2" OD.
Any suggestions?
https://linustechtips.com/topic/29115-need-suggestions-for-custom-loop/
so far looks good.. re-verify that GPU block and what you have. been a lot of XFX users
wrapped around the axle on the block not fitting certain version numbered boards.
Alphacool 360mm Radiator is this the XT or UT?
fans?
missing CPU block?
EK 7950 Block check for your version application
Bitspower 150 Reservoir fine
Swiftech 350 Pump ok choice
using stock pump top or another pump top?
Masterkleer Tubing 3/8x1/2 not bad..
Phobya 3/8x1/2 90-Degree Rotary Fitting, dunna know why not using koolance..
Bitspower Mini Valve for a system drain, nice..
airdeano
fans?
missing CPU block?
airdeano
It is neither a XT or UT (or at least I think). They call it a Monsta 80mm thick. In regards to fans, I have some black Xigmatek fans (Not sure on model). I forgot to include the CPU Block but it is an XSPC Raystorm. The EK 7950 Waterblock, I checked and they claimed it should fit my model number. I plan using the stock pump top. In regards to the 90 degree fittings not being koolance also, they were out of stock but happen to be in stock now so changing that.
EK 7950 Block
Swiftech 350 Pump
looks fine..
airdeano
