I built a custom loop about a year ago from the xspc ex 240 d5 kit and added 2 780ti's in addition to my 2600k. Having added 2 graphics cards to the loop, I also added an Alpha cool 60mm 280 rad in push-pull. From the general guidlines I've heard (120+120 per component) I should have more than enough. My CPU temps when gaming get into the high 70's to low 80's at stock clocks and voltages. Seems really high to me. The GPUs stay right around 50-60 depending on the game being played. Are my temps high or am I just being paranoid?
https://linustechtips.com/topic/291128-high-temps-on-custom-loop/
Hmm, you may need to clean out your loop. Usually every year is when you want to clean it.
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
How old is your thermal paste on the cpu? It might need to be replaced.
I am the one who goes bump in the night... usually making a sandwich.
Case: Phanteks Enthoo Primo White - Motherboard: ASUS X99 Deluxe - CPU: Intel i7 5820k - RAM: 4x4GB Corsair Vengeance 2666mhz ddr4 - GPU: Dual EVGA gtx 980 SSC - PSU: EVGA G2 Supernova 750w - Cooler: Custom PETG Loop on cpu and gpus - Storage: 500gb Samsung 850 evo ssd, 2x Seagate Barracuda 7200rpm 3tb hdd
you should be replacing the fluid in a custom loop every 6 months
also replace your thermal paste on the CPU
the CPU temps are high but GPUs are ok
The flakes could be nickle plating coming off of your blocks I would probably flush my system and redo the thermal paste to see of that helps.
the flakes could also be the plasticizer from the tubing used.
sounds like you have an air pocket in the CPU block prolly just over the main
core area. got a picture of the loop?
Dang I never even thought of a air pocket in the block itself
Enthoo Primo - ASUS Maximus Formula VII - 4790k 4.8ghz 1.28v - EK Supremacy Evo Clean - 16GB Crucial Ballistix Tactical - 1000w EVGA Supernova Gold - 2x Alphacool Monsta Rads in push/pull - 2x Galaxy 780 HoF with EK waterblock
Build Log http://imgur.com/a/UV6Wh Just want to warn everyone, my build log is pretty mediocre.
pretty common if the reservoir is lower than the CPU. trapped air hates to travel
downward, but loves to go up and if no relief, it hangs out in the CPU block.
So I thought I had found the problem when I took apart my loop and cleaned everything. I cleaned out the cpu block that was completely gunked up, replaced the fluid and thermal paste on the cpu,and 2 gpu block with MX4. Flushed the rads for 24 hours on a simple loop with some vinegar water. Got everything re-installed and booted up. Played some games and same problem. Also sorry for the very large pictures. Not sure how to make them smaller.
QDOs4hA.jpg?1
@Gunther78
totally backwards..
how much coolant was used?
If I had to guess? liter-liter and a half. 150ml res, 3 blocks, 280x60mm 240x30mm.
I know the loop is thourougly bled as well. I actually bled it while my case was sideways so the res was the highest point. pump has been running on an external power supply for ~2 days
1.5L sounds right. could be an airlock in the upper GPU no allowing full flow to
the CPU. the coolant in the res is swirling like mad? swirling? meh, moving?
pump at 12v? fans at 12v?
loop order (guessing) is:
res>pump>280>GPU (parallel)>CPU>ex240>res
Coolant isn't moving because the res is full. Good guess on the loop order. Pump is a D5 vario at 4. All the fans run at ~800rpm. The 280 is in push pull. Here's what I get after ~15 min of Dragon Age: Inquisition. The temps just keep rising until they level out in the upper 70's.
FojVXA7.jpg?1
on 4 that coolant should be jetting around in the res (if there isn't an air pocket).
might try this:
no power on system
lay pc on back
with rag/towel close by, slightly break the seal on the GPU stop plugs
(4-top ones, none of the side ones) till a drop appears. if the plug comes off and
nothing comes out, you have an airlock. has happend to me before.
might try this:
no power on system
lay pc on back
Just did that. Slightly broke the seal and water came out on all 4 immediately.
@Gunther78
k,
since the res is full, power off, rotate case onto its roof, observe res, if bubble
appears return to normal and power pump. if no bubble appears, burp power
to pump for 1/2 sec or less.
the only thing that does concern me is the little aerator fitting in the bottom res
cap. this should be on the top and not on the feed side of the pump. the holes
are sooo small and restrictive. ok for return to hold pressure in the feed lines,
but not direct pump feed.
@Gunther78
k,
I can drain it and remove that then, see if it helps. The flow is very slow, I drained a little bit out to observe it.
