RAM problems.
Go to solution Solved by Santipro,
Ok, I think I fixed it. Just ran ADW cleaner one and now theres only 246MB Ram changed... :D
Hi, I just started my PC and noticed I can only 14 out of 16 GB even tho I have not done anything strange! How can I set it back?
Plz help!
(The pic. is on german. I hope you understand... :PxD)
EDIT. Photoshopped it to english.. :D
EDIT 2. Same problem on Resource monitor...
OS: Windows 10 Pro | Case: Corsair Obsidian 750D | CPU: Ryzen 9 5900x | CPU Cooler: Corsair Hydro H110 | Mainboard: ASUS ROG Strix X570-E | RAM: 2x 16GB Crucial Ballistix DDR4 @3600MHz | GPU: Inno3D GeForce GTX 980 iChill X4 Air Boss Ultra | Main SSD: 1TB Corsair MP600 NVME | SSD1: 250GB Samsung 840 EVO SSD | SSD2: 500GB Samsung 850 EVO SSD | HDD1: WD Green 1000GB | HDD2: WD Green 2TB | PSU: Corsair AX860 | Mouse: Logitech G Pro Wireless | Keyboard: Logitech G513 | Headset: Logitech G933 | Monitors: ASUS ROG PG248Q & LG 29UM65-P
https://linustechtips.com/topic/290339-ram-problems/
As much as I'd love to speak German, my school gave me Spanish instead.
From what I can tell, you're using 4.4GB and you have some more as pool and cache and stuff...
But yeah. Something must be reserving the extra 1.8GB. Let me check in my system.
Sig under construction.
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942279
As far as I know, ram isn't used unless it's needed, so most will sit in "standby" ready to be written to up to a limit, after that unless it's needed it's just left idle. (From something I researched a fair while ago) It'll use more when needed I believe.)
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942341
Hmm, first time I've noticed that it does not match, I'm missing 100MB's.
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942371
I dont think so, beacuse it is the first time it happens... :P
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942380
I don't see a problem there.
You may go on the resource monitor and check the RAM there, its way more accurate and easier to understand than the task manager.
There might be some MB reserved for Hardware.
~ ThxAndBye
"You should remove any cats from the vicinity, because cats will cause all kinds of problems during CPU installation." -Linus
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942404
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942415
I need real RAM! D: Thx tho... xD
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942461
Can't see a problem though, it recognises 16GB, it will use 16GB, it's just task manager is only showing the active RAM not the standby ram.
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942472
Such legit ram. Much speed. No photoshop
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942502
This changed RAM might be a problem with one programm.
Close one programm every time and look if it goes away. Would suggest chrome first.
As i already said, there is no problem with your RAM.
All RAM is available and can be used by the system there is just a stupid program with some sort of stupid behavior.
Changed (Geändert) should be around 200-300 MB under normal conditions.
But you should only consider this a problem when you are running out of RAM.
Also if you have changed your page file (Auslagerungsdatei) settings you might get them back to recommended.
~ ThxAndBye
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942545
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942655
thx.. ^^
https://linustechtips.com/topic/290339-ram-problems/#findComment-3942660
