Monitor model name: ACER K242HLAbid
Specification:
Diagonal (inch): 24"
LED: Yes
Display type: TN
Resolution: 1920x1080 (16:9)
Contrast rate: 100000000:1
Light: 250
Response type: 2ms
VGA: Yes 1x
HDMI: Yes 1x
DVI: Yes 1x
Is this monitor good for gaming? Has anyone ever had it? Opinions? Viewing angle great? Colours are nice?
https://linustechtips.com/topic/290239-help-please/
It's good for gaming
Viewing angle is terrible
Colours are probably mediocre AT THE VERY BEST, expect bad colors
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/290239-help-please/#findComment-3940839
it will be fine for gaming its TN so do not expect the best colours or viewing angles, IPS would be the best option for a 1080p 60hz display
What is your location and buget
https://linustechtips.com/topic/290239-help-please/#findComment-3940840
Hungary, Budapest.
Max $170.
Could you recommend a monitor which has nice colors and wide viewing angle and at least 24 inch 1080p?
https://linustechtips.com/topic/290239-help-please/#findComment-3940859
Hungary, Budapest.
Max $170.
Are there any IPS monitors? not sure what stores you have access to
https://linustechtips.com/topic/290239-help-please/#findComment-3940874
