First off I want to know if their all compatible (gaming build)
CPU: I7 4790k
MOBO: MSI Z87-GD65 Gaming
RAM: G.Skill Sniper series 2x4 GB 2133 Memory
STORAGE: Kingston v300 series SSD 120 GB 2.5"
Seagate barracuda 1TB
CASE: Nzxt h440
PSU: Corsair CS 750W Semi
Graphics card??? I want a GTX around $200-$350 but I don't know which one!!??
https://linustechtips.com/topic/289648-second-build-need-suggestions-and-help/
Looks solid.
There's also a newer version of this motherboard, the Z97 Gaming 7.
The RAM is plenty fast, you could step down to 1866 MHz RAM and save some bucks there, maybe put that into a 256 GB SSD
the PSU has enough space for a typical SLI configuration. So unless you plan to do so in the future, I'd go with something lower wattage but higher quality like a CS 550
GPU-wise I'd say get a GTX 970. MSI, Asus, Gigabyte, those are all solid choices.
who cares...
