Just use DVI
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/289453-what-cable-to-use/#findComment-3929748
Like everyone else has said, DVI.
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
https://linustechtips.com/topic/289453-what-cable-to-use/#findComment-3929764
dvi
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/289453-what-cable-to-use/#findComment-3929771
see above
DVI
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/289453-what-cable-to-use/#findComment-3929788
