CPU: AMD 1050t Phenom II
Mobo: Gigabyte 990FXA-UD3
GPU: Gigabyte Radeon HD6970
PSU: Antec 520 watt
RAM: Gskills 8gb x2
Tried to turn on my pc last night, post screen popped up for a split second and immediately was replaced with a black screen, with a cursor prompt flashing and a mouse cursor. The cursor prompt goes away after about 2 seconds and the mouse cursor jumps to the right side of thr screen and the pc freezes like that. Happens everytime I turn it on now.
I've tried resetting the cmos, reseating the cpu and gpu and ram.
Any help would be greatly appreciated.
https://linustechtips.com/topic/289215-system-post-for-split-second-then-freezes/
PSU: Antec 520 watt
RAM: Gskills 8gb x2
Disconnect the hard drives and see if you can make it into the BIOS.
Does your motherboard have a debugging speaker / screen / or LED? Try with only 1 stick of ram then the other one at a time.
No speaker or LED, I'll do the ram next, I removed the cmos battery and have left it out, exact same problem.
