Need Help. Post-Assembly Testing Software & Other Questions
Solved by WoodenMarker,
1. Haswell --> Newer cpus handle voltage differently. Prime95 asks for too much and can be harmful. Benchmarks are good for testing stability but they aren't necessary if you aren't oc'ing.
Msi Afterburner can be useful for setting a custom fan curve as well as monitoring/oc'ing. Brand doesn't really matter.
2. The software can be useful when needed. I otherwise don't touch them.
3. Updating the bios is good. There's also the saying of 'don't fix what isn't broken' and keep in mind that anything you do is at your own risk.
4. Oh.
5. It would help to list your build..?
