I recently built a new pc using the CM Storm Stryker and I want to add case fans on the bottom, and maybe replace the ones on the front. I don't have a specific budget in mind, because I don't know how much they should cost. However I still need to know, what are the best case fans, especially for mid-to-high end price ranges? They need to be 120mm.
https://linustechtips.com/topic/289118-best-case-fans/
i'd get some AP121's if youre looking for 120mm. I have some noctua PPC ones but im going to return them, they have this ticking noise that makes me mad
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/289118-best-case-fans/#findComment-3925341
I like Corsair AF/SP fans. I have a few Noctuas but can't justify the price.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/289118-best-case-fans/#findComment-3925352
