adblocker dosnt work properly
Go to solution Solved by QueenDemetria,
i checked the extension and nothing.... where do i need to look?
http://malwaretips.com/blogs/hq-video-pro-1-9-virus/
This guide should remove it.
i still get as pop ups and i can still see ads all over and sometimes only their frame of an ad
an example for the ad frame
Actually, since linustechtips doesn't currently have ads, a plug-in(or possibly virus) must be causing the ads. My guess is that "HQ Video Pro" is causing this, so you might have to disable this application(plug-in) in your extensions menu.
In related things. I currently seem to have a bit of malware affecting my Chrome. It's popping up malicious ads, but ONLY when I go to a certail twitch stream page, EVERYTHING else is fine :P
Gotta l;ove this stuff.
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
Gaming Laptop: Dell G5 5587
