Ik ik, Colored coolant is a bad path to choose in terms of maintenance and I should just go with distilled water... however I am going to be using acrylic tubing and I really want it to look amazing.
That is the colored coolant I am looking for just red.
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/288019-red-coolant/
You would just have to add dye to the water.
https://linustechtips.com/topic/288019-red-coolant/#findComment-3911474
Mayhems Dye looks absolutely awesome, but I've heard it degrades quickly.
Although I've also heard the newer stuff lasts a lot longer, check them out, absolutely awesome looking dyes.
CPU i5 6600K | Mobo Gigabyte Z170X Gaming 7 | Cooling H80i | MSI GTX970 Gaming 4GB in SLi | Geil Super Luce 16GB 3000MHz DDR4 | Intel 330 120GB | 2 x 1TB WD Black | Corsair Air 540 | XFX ProSeries 1250W. | Corsair K70 Anodised Black Cherry Reds | Logitech G502 | Dell U2713HM | Red LED Lighting.
Portable Gamer - Metabox Alpha W370SS - CPU i7 4710MQ | RAM 8GB 1600MHz | Nvidia GTX 860M 2GB GDDR5 | Samsung 840 EVO 250GB SSD | 17.3" Matte Display 72% Gamut
Back-up - HP Pavilion dv6 - Ancient Stuff - P7550 @ 2.26gHz  | DDR2 4GB | Kingston HyperX 120Gb SSD | ATi 4550m (fried)
https://linustechtips.com/topic/288019-red-coolant/#findComment-3911489
And that still gets a deep red affect? I am afraid it will look like a watered down red
https://linustechtips.com/topic/288019-red-coolant/#findComment-3911490
put enough dye in, and the right kind of die and it should look at least close to solid if not solid.
https://linustechtips.com/topic/288019-red-coolant/#findComment-3911518
That may be what I need, thanks :D
Check out this Geforce Garage video that shows how the dye works
Starts at 6:40 if the video doesn't start the auto play at 640 right.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/288019-red-coolant/#findComment-3911523
