So i have the old coolermaster gx650w bronze. Every 1hour or so the fan increases its speed from its normal speed to a high speed(sounds the same as my gpu on 60% fan load xfx dd). The speed last for 10seconds always, is there a reason for this, is it a problem, should slick be fired?
Listen if you care.
https://linustechtips.com/topic/28712-psu-fan-weirdness/
You might need to get a new PSU.
try giving it a good clean with bursts of air from a compressed air can. if you can't get one then try to use a vacuum and a couple of swabs.
I brought it two days ago.the psu was on sale.
Listen if you care.
https://linustechtips.com/topic/28712-psu-fan-weirdness/#findComment-365055
RMA
I dont think its a problem, i think it might be hot and after ten seconds of higher level cooling it reverts to its old level, its only noticeable because normally i cant hear the psu fan which might mean it wasnt on until then. I have been gaming for 80% of these last few days so that might be part of the problem.
Listen if you care.
https://linustechtips.com/topic/28712-psu-fan-weirdness/#findComment-365074
