I have finally installed the Wifi/Bluetooth chip that came with my Asus Maximus IV formula motherboard. I wanted to find a relatively cheap M.2 SSD that can fit in this chip so that I can have it be a boot drive for my PC. I was thinking about getting a 128Gb drive but I do not know where I should look or trust. Also if there is a better option let me know like a really cheap 240gb.
Thank you,
Josh
https://linustechtips.com/topic/286937-m2-help/
Samsung XP941 if you want crazy performance, otherwise the Plextor M6e should be good enough
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/286937-m2-help/#findComment-3895877
Where are you shopping/located? Budget?
https://linustechtips.com/topic/286937-m2-help/#findComment-3895878
How much were you looking to spend on one?
I am in New England in the US and the budget is really like no more than 150-200. I am only looking for a boot drive because this would be over kill for games.
https://linustechtips.com/topic/286937-m2-help/#findComment-3895913
What does that mean..?
Any reason you're going with an m.2 drive instead of sata?
https://linustechtips.com/topic/286937-m2-help/#findComment-3895938
Off-topic: there is a IV Formula??
With M.2 support? ;)  Think it's probably OP isn't used to roman numerals. (So VI or VII is much more likely).
[Main rig "ToXxXiC":]
CPU: Intel Core i7-4790K | MB: ASUS Maximus VII Formula | RAM: G.Skill TridentX 32GB 2400MHz (DDR-3) | GPU: EVGA GTX980 Hydro Copper | Storage: Samsung 850 Pro 256GB SSD + Samsung 850 EVO 1TB SSD (+NAS) | Sound: OnBoard | PSU: XFX Black Edition Pro 1050W 80+ Gold | Case: Cooler Master Cosmos II | Cooling: Full Custom Watercooling Loop (CPU+GPU+MB) | OS: Windows 7 Professional (64-Bit)
https://linustechtips.com/topic/286937-m2-help/#findComment-3896220
HAHA sorry about that, that it is a VI and I wanted to use it for a fast boot drive because I am using a 5 year old SSD which is now bogging down.
https://linustechtips.com/topic/286937-m2-help/#findComment-3896586
So where are you shopping from? --England or the US?
https://linustechtips.com/topic/286937-m2-help/#findComment-3896603
It means that he lives in New England, in the USA. lol
I can't see your problem
Oh, my bad--I had a brain fart.  -_-
Considering pricing, I'd suggest getting a sata ssd instead: http://pcpartpicker.com/part/crucial-internal-hard-drive-ct256m550ssd1
https://linustechtips.com/topic/286937-m2-help/#findComment-3897877
