Headphone and Mic suggestions? 3.5mm jacks or usb?
EternalSeeker
As the title suggests, which one should I go for.
I will use the headphones and mic for skype calls, hangouts, teamspeak, etc.
My mobo is the x99s sli plus. I listen to most of my music on my speakers, though if the headphones are good I might use them. Also any speaker suggestions would be nice but not mandatory, for now looking for just headphone and mic suggestions.
Thanks
Specs: Case: NZXT H440 ] CPU: I7-5960x | CPU Cooler: NZXT Kraken X61 AIO | MOBO: ASUS Rampage V  | GPU: Gigabyte G1 Gaming GTX 970  | RAM: Gskill Ripjaw 4 16GB 2133Mhz DDR4 kit | PSU: EVGA 1000G2 | SSD (Boot): Samsung 850pro 128GB | HDD (mass storage): WD 1TB Blue 7200RPM  | SDD (Working Drve): Samsung 850 evo 500GB | Keyboard: Logitech G510s | Mouse: Logitech G502 Proteus Core | Display: Asus VG248 24in. 144Hz 1ms
SNIP
Budget?
I swear by my beyerdynamics mmx300 but not cheap
Budget?
$100-150 range cdn.
$100-150 range cdn.
There is only one recomendations
Hyper X Cloud (if you want a headset)
if not get some sennhesier HD449s and a mod mic ( or 429s if you wanna spend less) 280s pros are good too
Yeah I was thinking of mod mic 4.0 plus a really good headset but is getting a usb headset better? Do I "need" an amp?
Not a fan of usb headsets
no you dont need an amp/dac or anyting, generally they are only good for $250 headphones and up
439 would be the correct model to recommend because it is the only 400-series set that has a removable cable.
Good point :)
Hey guys, I looked at both Newegg and NCIX, couldn't find the HD 439? Is the Momentum good as well? I can probably get a Mod Mic 4.0 from massdrop so that's not a problem. By the way the mobo runs
Realtek® ALC892 8-Channel High Definition Audio CODEC,
So I don't know how may ohm the rear I/o can pull. Also what is the best way to set up the audio on the pc such that it runs off the speakers (my current 2.1 or if I choose to go surround) and then have a switch or such to turn it off once the headphones and mic are connected? I highly doubt I will be taking these headphones outside of my house though.
