I get the 970. 970 is the best price/performance out there. The 780 cost just as much as the 980.
Remember a wise man once said, "You'll most likely hear/see more bad reviews from products than good, because if they get a good product, they won't bother to write a review, and if they got a bad product, they'll complain about the product" ~ SoftenButterCream
EVGA GTX 780 3GB 384-bit DDR5 Dual Bios with ACX Cooler
vs
GIGABYTE GTX 970 DDR5 4GB GRAPHICS CARD (TELM/T)
Which one will YOU choose ?
The performance is very similar. But the 970 has 1 more gb of VRAM. It depends on the price. If they are the same then 970.
I'd go with the 970
PC: CPU: Ryzen 5 5600X @ Curve optimzer -25,  Cooler: Noctua NH-D15 Chromax.Black, Motherboard: Asus Rog Strix B500-F Gaming WiFi II, GPU: Sapphire Nitro+ RX 7800XT @ Stock , RAM: G.Skill Trident Z RGB 2x16GB DDR4 3600Mhz CL18, HDD: Western Digital Caviar Black 2TB, SSD: Samsung 850 Evo 250GB | Team Group MP33 1TB NVME, Case: NZXT H7 Flow Black, PSU: NZXT C1200  I Peripherals: Keyboard: Ducky Shine 6 RGB Special Edition, Mouse: Razer Orochi V2, Headset: Philips SHP9500, Mousepad: Glorious Stealth Extended I Laptop: MSI GS63VR Stealth Pro CPU: i7-6700HQ@ 2.6ghz, GPU: GTX 1060, Memory: 16GB DDR4 2400Mhz, HDD: 1TB+128GB SSD
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
We are not nerds
We are experts ;)
The GTX970 is newer and less power hungry and has better OC headroom
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I had both chips and they are very similar in performance. Sometimes the 780 wins, sometimes the 970.
For the same price i'd go 970.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Please use the MultiQuote function.... and get a GTX970.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
@Saint9999 There´s a function called multiquote, it´s next to the regular quote button, just press the MultiQuote button on all of the post you want to quote, and then press the Reply to [X] quoted post(s)
We are not nerds
We are experts ;)
no more posts need to be made, this is all you need
 badges badges badges badges badges badges badges badges badges badges badges badges badges
