Help cant decide what PSU
Go to solution Solved by Aniallation,
Yes i want to get another 970
@Aniallation its B2
Then definitely get the CM V700, it's the best out of the three hands down, and will easily be able to handle a second (even third) 970.
i have an stock 4790k (atm) and a gtx 970,
i've seen options but i don't know which one to get
CM V700Seasonic M12II 850 or EVGA Supernova 850
i've haven't seen the EVGA 750 G2 anywhere in my country, CM and M12II are at same price
What Supernova 850 is it? G2 or B2?
If it's G2 then it will be the best out of the three, followed very closely by the V700. The Seasonic M12II is a lower-tier PSU, so wouldn't consider it in this comparison.
You will not need anywhere near 850W even if you add a second 970 and overclock your entire system. If the EVGA is G2 then get whichever's cheaper between EVGA and CM. If it's B2 then hands down get the CM
"Rawr XD"
