i need a little help
By
Palfi
in Troubleshooting
in Troubleshooting
Solved by DEDRICK,
You can typically force a program to run either from integrated or high-performance by Right clicking the shortcut and choosing the correct option (This menu must be enabled in nVidia Control Panel). This option overrides whatever you have set up as your preferred.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
