Cryorig R1 Ultimate replace/remove fans?
Hi, i bought a Cryorig R1 Ultimate CPU Cooler & i'm asking myself if i could run the cooler with fans from another brand or even remove them completly?
I'm using a i5-4690k in a well cooled Fractal Design Define R5
Thanks to all comments :-)
CPU: Intel i5-4670 | Motherboard: MSI Z87-G43 | RAM: Kingston Hyper X - 2x 4GB DDR3-1600 | GPU: Gigabyte 760 OC | Case: Zalman Z9 | Storage: Samsung 128GB SSD & 500GB Toshiba HDD | PSU: bequiet! Dark Power Pro 10 - 650W | Display(s): ASUS 2x VG248QE | Cooling: be quiet! Dark Rock 3 | Mouse: Mad Catz - R.A.T 3 | Operating System: Windows 8.1 Pro (64bit)
https://linustechtips.com/topic/286282-cryorig-r1-ultimate-replaceremove-fans/
@Lays has one, so he probably knows.
You should be able to replace the fans, though I don't see why you would.
Yeah you can replace them with another 140 mm fan. I dont know why you would. I personally own the same cooler and do not have any problems with the fans at all.
Why  do you want to replace them?
