So I just built a brand new PC;
Intel i7-4790k @4.0GHz
ASUS Z97-AR Motherboard
Geforce GTX 970 SC
750W EVGA Power Supply
2TB HDD
Corsair H60 Liquid CPU Cooler
So my question is, what is the safe temperature range? When i first turned on my computer, my CPU was running around 56 degrees. I just want to know what the safe range is so i can keep an eye on it.
https://linustechtips.com/topic/286121-safe-pc-temps/
Geforce GTX 970 SC
2TB HDD
56c is a bit high when it comes to idle temperatures. Have you tested temperatures under load? your cpu block may need to be remounted.
Quantum Chaos: i7 6850K | 2x Strix 1080Ti SLI | MSI X99 SLI Krait | 32GB Corsair Vengeance LPX | Samsung 970 EVO 500GB | 3TB WD Red RAID 1
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3885491
I haven't checked that yet, but it was pretty warm in my apartment when i first turned it on.
Above 85 is when I start to worry about my load temps, generally liquid coolers keep your idle temps at about 5-10c ambient so your temp is higher than I would expect.
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3885515
Will do. What is safe under load? Say, playing Watch Dogs oh full specs.
Safe is under 90, your cpu will shut itself off at 100 but I never like to go above 85.
so what should i do? What would you recommend?
Just run something like AIDA64 and see what your load temperatures are.
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3885529
Anything over 90 is scary. Anything over 95 is horrid. Mine gets around 55 under load.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3885530
idle should be under 40. IMO
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3885541
So what would you recommend i do to fix this?
better case airflow, better cooler, but first try re-mounting the cooler.
-Jim Hensen
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3885544
Check the load temperatures, and if they are really high you might have an issue with the way the CPU block is mounted.
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3885545
alright, ill try remounting the cooler first then remount the cpu block if that doesnt work
remount.
then airflow.
then different cooler.
those are the best steps really...
be sure to come bacl to us if the remount doesnt work! :D
-Jim Hensen
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3885600
So, i didn't remount or anything yet, but i checked and saw that my cpu cooler was loose, so i tightened that. Now it's fluctuating between 34-50 degrees while downloading an update for a game and downloading an entire game while running google chrome and spotify. Would you say that's normal? My room is also roughly 68 degrees Fahrenheit. Once i get Hitman: Absolution downloaded, i was going to run the first mission and see how it did then, but for now, this is what i have.
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3887424
remount.
then airflow.
https://linustechtips.com/topic/286121-safe-pc-temps/#findComment-3887430
