Basic Web Dev question(s)
Go to solution Solved by LukeTim,
So you give a div a class then within the class, you write the required amount classes?
You simply include the names of all the classes you want in the class attribute of the div, separated by spaces.
<div class="a_class another_class"></div>
Q. How do you write several classes at the same time?
A. You give a div a class then include all the classes you want in the "class" attribute of the div, separated by spaces.
Ex. <div class=" foo bar aaa "></div>
Edit: This is one of the many questions I have in homework.
Q 2. What does the attribute Title do?
A. It defines a title, and some information which you can look at while the site loads ..?
Q 3. What's wrong with the following code?
<img alt="blomma" title="blomma" src="b.jpg />?
A. Alt and title can't be the same thing since it's like alt not even being there. Alt isn't contributing with anything.
Are the answers I have written/gotten correct?
I am translating this from Swedish.
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/285716-basic-web-dev-questions/
Won't writing one by one be better and more efficient ?
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879274
I have this question for homework and several others.
But yes it's a weird question.
Not sure what you mean, you can just give divs classes
<div class='whatever'>
stuff
</div>
So that you can easily style with CSS or whatever later
.whatever {
     color: '#fffff';
So you write several Divs and then classes within the divs?
Can I only do 1 class within 1 div?
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879306
You can nest Divs with classes like so
<div ='div1'>
      <div='nested_div'>
      </div>
</div>
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879345
<div ='div1'>
      <div='nested_div'>
      </div>
</div>
So that is an almost yes?
I am confused.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879362
This is what you want to do:
<div class="class_1 class_2 class_3"></div>
.class_1 {}.class_2 {}.class_3 {}
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879422
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879438
Ok, I think I understand.
Do you know how to answer the other questions too? :-)
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879459
Title just defines the title of the page. This is displayed in the title bar of the browser window. It may have some other obscure functions defined in the HTML spec, but I don't know if or what they are...
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879487
As above, it defines the title of the page, that is, what shows on the tab and/or in the browser window depending on the browser. Some HTML specs require a title to be valid
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879531
So this is enough?
On the question sheet I have 2 rows to answer.
I think they want a longer answer.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879537
For Question 2:
The title tag in the head section defines the Title of your webpage.
<head><title>Your Page Title</title></head>
The title attribute represents information about the element. For example, for a link this could be the title of the Linked Page/document or for an Image this could be the name of the Image.
<img src="linktofile" title="This is awesome - Webpage" />
Business Management Student @ University St. Gallen (Switzerland)
HomeServer: i7 4930k - GTX 1070ti - ASUS Rampage IV Gene - 32Gb Ram
Laptop: MacBook Pro Retina 15" 2018
Operating Systems (Virtualised using VMware): Windows Pro 10, Cent OS 7
Occupation: Software Engineer
https://linustechtips.com/topic/285716-basic-web-dev-questions/#findComment-3879541
