Need Help Finding New Mobo
Go to solution Solved by Untouchable,
I found this motherboard for you. Its fairly decent. It also has fairly good reviews. It should handle to 8350 no problem. Tell me if you have any concerns!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128565&cm_re=am3_motherboard-_-13-128-565-_-Product
Alright first off
System Specs:
 Motherboard: ASRock 960GM/U3S3 FX AM3+ AMD 760G + SB710 SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
 CPU: AMD FX 8350
 GPU: GTX 750 ti
 PSU: Dynex DX-520WPS (520 watts peak, 420 watts total)
Alright so I already figured out my motherboard is faulty, so all i need is a am3+ motherboard under $70 preferably usb 3.0
Thanks for anyone taking time out of their day to find me one, i'm just not confident enough in my own picking to find me one
https://linustechtips.com/topic/285200-need-help-finding-new-mobo/
Can't you RMA the board?
I sound really picky right now but whatever
I need one with a chasis fan
