Hey guys,
So I am following Linus' buyer's guide and am looking to make this machine ( : http://gyazo.com/ff8a6b6db654fe63b3ce4f6afab6e5cc ).
I am making some minor adjustments, instead of 16GB RAM I take 8 GB and I already have a SSD and HDD and GPU ( GTX 970 ).
But the problem is, the power supply is not sold in the Netherlands not in online or normal stores.
So I need help finding a replacement for it.
So instead of the Corsair HX750 I have to buy the .............
Same specs and around the same price please.
Thanks for helping!
https://linustechtips.com/topic/284873-building-pc-need-help/
@Logix_X
EVGA G2 750W
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867347
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867353
Yep, that one is incredible
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867355
Thanks for the help fellow Dutchman, could you help me with my cooler too please? http://linustechtips.com/main/topic/284874-building-pc-need-help/
If it must be AIO then the Corsair H110 or H105, otherwise the NH-D15
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867367
Well I am following the Buyers Guide and the Nepton was a Liqiud cooler.
What would you suggest?
NH-D15 is quieter, more reliable and has about the same performance of an AIO but is bulky and pretty ugly if that matters to you but I recommend the NH-D15.
Nothing wrong with AIO's though
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867386
I dont care about the looks are something, it is about the performance at the end of the day.
I'll take the NH-D15 then, thanks
But wait, I got some spare money left, so I can do 2 things, go from 8GB RAM to 16GB RAM or instead of the i7 4770k the 4790k. ( could do both if it brings alot more performance. )
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867392
Do check that the NH-D15 is compatible with your case before ordering it
As for the upgrade I say go with a good Z97 board and 4790k (Much better temps and 0.5GHz higher stock clock, very much worth it) and get 16GB later
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867400
Thanks will surely look into this, but the Case I am getting is the Enthoo Pro from the video, should fit right?
BTW this mobo? http://tweakers.net/pricewatch/383995/asus-z97-a.html
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867415
Yeah, that will easily fit
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867418
It's an option
Other options include:
MSI Z97 Gaming 5
MSI Z97-G45 Gaming
Gigabyte Z97X-SLI
Gigabyte Z97X-Gaming 5
Asus Z97-A (or AR)
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867423
You are my man, can you give me what you would suggest? I am a newb at these things.
MSI Gaming or Gigabyte gaming is you want good onboard sound and a cool looking board
Asus Z97 for a more well-rounded MB with an intel NIC
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867438
Sound in important to me, + my 970 is Gigabyte G1 so...
If sound is important then go MSI or Gigabyte indeed.
I personally would go with MSI Gaming 5 but I just like that board :D
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867445
http://tweakers.net/pricewatch/385033/msi-z97-gaming-5.html , go or no go? You know it better than me
Yep, that's the one, good board for the 4790k
https://linustechtips.com/topic/284873-building-pc-need-help/#findComment-3867457
