If i take off a waterblock, do i need to re aply anything other than the thermal compound directly on the chip?
Can i take off a waterblock, put on heatsink, use for a while, and put waterblock back on?
https://linustechtips.com/topic/284444-taking-cooler-onoff/
Of course.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/284444-taking-cooler-onoff/#findComment-3860995
yes but why?
Want to buy card on ebay with waterblock, my system isnt watercooled yet, so ill use it with heatsink, watercooling in a month, put block back on.
https://linustechtips.com/topic/284444-taking-cooler-onoff/#findComment-3861020
yes its fine. question is where are you going to get a heatsink?
https://linustechtips.com/topic/284444-taking-cooler-onoff/#findComment-3861030
Guy selling card has stock heatsink too
https://linustechtips.com/topic/284444-taking-cooler-onoff/#findComment-3861046
