I built this guy just over 2 weeks ago and so far it's been fantastic. It is my first build and my budget was tight so I did have to skimp on some things.
[All parts purchased at my local Micro Center]
Current specs:
CPU: Intel Core i5-4690k 3.5ghz (I'm too scared to overclock with the current cooler xD)
GPU: Asus Strix GTX 970
Cooler: Stock
RAM: 8 GB Crucial Ballistic
Motherboard: ASRock Z97 Pro4
Storage: 1tb WD Green
Case: Zalman Z12 Plus
PSU: Corsair CX600M
Specs I hope to have after upgrading:
CPU: Intel Core i5-4690k (Overclocked to who knows what)
GPU: Asus Strix GTX 970 (Overclocked)
Cooler: Hyper 212 Evo
RAM: 16 GB Crucial Ballistic
Storage 1: 1tb WD Green
Storage 2: 250gb SSD (either Intel or Samsung)
PSU: Corsair CX600M
After thoughts:
-I would not recommend this case or motherboard, the case especially was a pain to work with.
-I know the cable management isn't great but I was having trouble because the case didn't have much room for cables on the other side.
-I haven't attempted overclocking yet and won't until I get a new cooler
-I'm using the stock fans that came with the case
https://linustechtips.com/topic/283517-my-first-build-3/
Looks awesome! Sure way better than my first build!
also what monitor is that?
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/283517-my-first-build-3/#findComment-3848299
It's the Asus VN247H, I bought it along with my parts for like $170 or something like that. The 1ms response time was attractive to me because I play a lot of CS GO :)
https://linustechtips.com/topic/283517-my-first-build-3/#findComment-3848347
And to think I almost bought a pre-built because I was timid about screwing up the parts
I watched about 10 detailed videos on youtube before I put together my PC and still was not really confident :'D
But in the end everything turned out well.
And failing to act, for fear of the risk, is no different than a living death. No matter what world you’re in.
https://linustechtips.com/topic/283517-my-first-build-3/#findComment-3849584
Nice and tighty :) Good work.
My Rig: CPU - Intel i7 2600k OC @ 4.5 GHz | CPU Cooler - Coolermaster Hyper 212+ (Push & Pull) | Motherboard - Asus P8P67 Deluxe | RAM - Corsair Vengeance 16GB 1600GPU - EVGA GTX 980 (SC) | Case - Coolermaster HAF 932 Advanced Blue Edition | PSU - Corsair TX850W | DisplaysDell S2417DG, BenQ XL2420T | Keyboard - Logitech G213 Prodigy |  Mouse - Logitech G303 | Headset - Sennheiser PC363D | Questions? Twitter=@Mattler119
https://linustechtips.com/topic/283517-my-first-build-3/#findComment-3871329
Make sure the Hyper 212 Evo will fit before you buy, I've done that before lol
https://linustechtips.com/topic/283517-my-first-build-3/#findComment-3871360
Very nicely done for a first build :) But I will never understand why some motherboard manufacturers put a molex connector in the middle of the board, just why? :D
This motherboard was such a pain to work with lol. As a first timer it really made things difficult, don't think I will be going with ASRock again. I will be building my friends PC after he gets paid and I think I will recommend he get an Asus board or something. Also, thanks. I worked hard on it :)
https://linustechtips.com/topic/283517-my-first-build-3/#findComment-3875610
Oh damn, I didn't think about that. I shop at micro center though and the employees are quite knowledgeable so maybe I'll ask them before I buy
Your lucky you live near a Microcenter, the closest one to me in Pennsylvania is like an hour or two away......
PC Specs   - Black and White Build
    Intel Core i5 4690k MSI Z97S Krait LGA 1150
    Crucial Ballistix Sport 1x8GB 1600MHZ
    Sapphire Radeon R9 270 (Will be upgrading this soon)
    EVGA 500W PSU
    Phanteks Enthoo Pro - White
https://linustechtips.com/topic/283517-my-first-build-3/#findComment-3883728
