If you don't OC, the Xeon E3-1231 V3 is the best alternate to the i7 out there.  Depending on the price an R9 290X would be cheaper (obviously it's a space heater)
Otherwise theres the i5 if you OC, and the AMD octo-cores (FX line) that are fine but just are not as good as other cards.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/283337-new-pc-build-need-help/#findComment-3846035
i wont overclock , and what i5 model are good ?? , please suggest a nvidia card , i already have a amd card and had a bad impression
https://linustechtips.com/topic/283337-new-pc-build-need-help/#findComment-3846055
Otherwise theres the i5 if you OC, and the AMD octo-cores (FX line) that are fine but just are not as good as other CPUs.
I believe you meant that. ;)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/283337-new-pc-build-need-help/#findComment-3846058
Remember the Xeon's performance though I bet the pricing through countries hurts though since it's a less demanded product...
The i5-4690K is the best i5 but any and all are good.
As for the GPU the GTX 760 exists and performs well but isn't anywhere as fast...
As for a good replacement the GTX 780 or GTX 770 are the only good competitors but if you go a bit higher, you'll get the 970...  Hard to recommend anything but the 970, i'm sorry to say.
https://linustechtips.com/topic/283337-new-pc-build-need-help/#findComment-3846098
thanks .
https://linustechtips.com/topic/283337-new-pc-build-need-help/#findComment-3846116
9370=
CPU: i5 4690k @ Stock | MOBO: Asus Z97 Pro | RAM: A-Data 1600MHz | GPU: Asus DCU2 GTX 770 | Storage: Crucial MX100 & Toshiba 1TB | Power Supply: Corsair HX650 | Case: Corsair 450D
this build seem good , how much it cost u ? any idea on improving it ?
https://linustechtips.com/topic/283337-new-pc-build-need-help/#findComment-3846175
