Has anyone ever tried mounting a EK-X Res 3 150mm to a 140mm location using this: http://www.frozencpu.com/products/14357/ex-rad-319/Bitspower_140mm_Water_Tank_Mount_Panel_BP-140WTMP-BK.html?id=VryywPHK&mv_pc=13813
I just want to know if the included mounting hardware with the res will work with the mounting holes on the bracket. I can't find any specs on eks mount to see what the spacing is for the holes.
Thanks!
AMD diehard & Nvidia Enthusiest
https://linustechtips.com/topic/283003-res-mount/
