Phobya watercooling kit
Yesterday i was litle tired so today i done what you told me, and picking the same parts by myself would cost me 235e ( with smaller and cheaper res) for kit that they are selling for 175e, then with d5 pump would cost me 265 or 290 depending on pump ( 265 for without fittings you just put tube on it and it is plastic, 290 for pump where you can put fittings).
Maybe would be best later on selling that pump and those parts wuold cost me like 150e and just buy alphacool vpp655 pwm and would cost me 240e instead 290e. What you think?
That's a pretty good pump too, It's from Laing as well as the D5 is. This one is actually pretty powerful too! You won't even need to run it on a higher setting, even with a extra couple rads.
There seems to be a lot of savings on these kits, usually on US websites like FrozenCPU, getting the set, or the same parts separately has almost the same price. So go for it! Change as you upgrade.
