Help with wireless card!
Go to solution Solved by NeatSquidYT,
Probably not, unless the wireless card comes with the mobo. Use the CD that comes with the wireless card.
So later today or tomorrow I am going to help a friend build a new PC. I have built one myself and think that it is really easy and I'm at least above the novice level of PC building, but I am wondering about how I am supposed to get his wireless card to work because wireless is the only thing he can use to get connected to the interwebs. I think I can use the CD that comes with the wireless card to install the drivers, but I'm wondering if the included CD drivers that come with the motherboard will work? Any help would be appreciated!
https://linustechtips.com/topic/282864-help-with-wireless-card/
