Hey
Happy New Year :D
I am from Denmark and I am going to build my first PC.
Here is the link for the parts: http://uk.pcpartpicker.com/p/9d73jX
I do not know which CPU I will choose, Intel Core i7-4820K Ivy Bridge-E or Intel Core i7-4930K Extreme IV-E.
Or, is the new LGA-2011-V3 better? I chose LGA-2011 because the motherboard has the possibility to Wi-Fi 802.11ac, OC panel (and maybe later ROG front base) and the onboard sound card.
What do you think? Are there points of improvement?
Thanks for your help  :)
I look forward to hear from you
https://linustechtips.com/topic/282781-first-gaming-pc-build/
get a x99 mobo such as the Asus X99-PRO and change the Ram to DDR4
get a different cooler : Corsair H105
go with Intel Core i7-5820K if you get the x99 mobo
CPU:AMD FX-8320, RAM:Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600, GPU:MSI Radeon R9 280, Case:Cooler Master 690 III, PSU:Thermaltake Smart 650W
Storage:WD Purple 1TB, CPU Cooler:Hyper 212 EVO, Keyboard:SCI Granite, OS:win 8.1 64bit, Display:Samsung SyncMaster SA100, Mouse:CM Storm Spawn
https://linustechtips.com/topic/282781-first-gaming-pc-build/#findComment-3838977
Yes  :D I had a year ago bought a new laptop(with i7, 8GB ram, Nvidea 2GB), but it cant handle all games, like BF4 etc. and others games are not so smooth, even though it costed 8000 KR, now with a battery that does not work...
Then the 2011-3 platform is a waste of money ;)
"an obvious supporter of privacy"
https://linustechtips.com/topic/282781-first-gaming-pc-build/#findComment-3839462
What about the 4820k? just because I can buy the Asus Rampage IV Black Edition and use some of the features and in the future have the Rog Front Base from Asus
You don't need it.
https://linustechtips.com/topic/282781-first-gaming-pc-build/#findComment-3840070
