Water Cooling Prices
Solved by everything count to life,
Ok thanks. If I planned on adding another gpu in the futre do you think it could handle it? Also what kind of extra rad size do you think the h220 could accommodate, like could I attach a 480 mm rad to it also (I highly doubt it)?
Well that's the problem with the H220 expanding its really only made for one gpu because the pump can't handle a lot of rads or big rads so if you want to add a gpu in the future you better off with a custom loop
