Hi, I'm planning on building a gaming/school pc. Specifications
Intel core i7 4790k
HyperX savage RAM 16GB
EVGA or GIGABYTE nvidia GTX 980
ASUS Z97 pro mother board
Kingston 480GB SSD
2TB WD green hard drive
Cooler master V8GTS
4x corsair fans 120mm
2x corsair fans 140mm
Corsair 750 or 850W power supply
In a corsair 780T case, love to know what people think and what they would change. Many thanks
https://linustechtips.com/topic/282070-help/
Intel core i7 4790k
Kingston 480GB SSD
Cooler master V8GTS
pc part picker pls next time
you over clocking?
if not drop the k
overclock the gpu for sure xD
https://linustechtips.com/topic/282070-help/#findComment-3829793
Would only like as not sure how dual graphic cards work yet, as it will be the first time I build a computer. Thanks for advice
with AMD cards all you need is a compatible motherboard and you just need to enable it in the included software and done
with NVidia cards you need a compatible motherbaord but you need to plug in the SLI bridge that usually comes with the motherboard then you enable it in the software
https://linustechtips.com/topic/282070-help/#findComment-3829859
Thanks for advice, but won't be doing much hard core gaming. Just want a good all rounder, that will last and also will have good tech.
https://linustechtips.com/topic/282070-help/#findComment-3829874
still more power for the same amount of money
https://linustechtips.com/topic/282070-help/#findComment-3829882
the Cooler master V8GTS Is expensive choice for a non overclocked system
you could get a http://www.amazon.com/Be-Quiet-Silentwings-Cooler-LGA775/dp/B00HPX7J4K/ref=sr_1_1?ie=UTF8&qid=1420135302&sr=8-1&keywords=dark+rock+pro
or something cheaper also go with a non K series Chip ( if your not over clocking)
I personally dont like SLI or crossfire so going with the solo 980 would be my choice
and you only need a 750W PSU for this build also I would look at EVGA for your PSU they are just as nice and cheaper
https://linustechtips.com/topic/282070-help/#findComment-3829950
Thanks for advice. Are you in America as the cooler in uk is only £40
https://linustechtips.com/topic/282070-help/#findComment-3829969
What GTX 980 brand would you go with
https://linustechtips.com/topic/282070-help/#findComment-3829976
Thanks
Going with a single 980 now is a good idea. In the future the 980 are going to drop in price so you will be able to pick up a second or 3 and still have a beast system ware as the dual 970 are good right now for the price in the future there is not much room to expand them.
and cross firing R9 series card is silly for the amount of heat and power they use for the performance
https://linustechtips.com/topic/282070-help/#findComment-3830165
Updated plan please feedback would help
Intel core i7 4790k
EVGA nvidia GTX 980
Samsung 480 EVO 500gb
Cooler master V8GTS
5x corsair fans 120mm
3x corsair fans 140mm
Corsair 650W
https://linustechtips.com/topic/282070-help/#findComment-3834676
Intel core i7 4790k
EVGA nvidia GTX 980
Cooler master V8GTS
Corsair 650W
I don't know anything about the case but this will work great at 1440p and 2-3 screens.
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/282070-help/#findComment-3837855
thank but i will only be running one screen
What resolution?
And is it 60hz monitor or higher?
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/282070-help/#findComment-3847204
