I was going to post in the air cooling section, but considering the last post was an hour ago; I assumed that no one was on that sub forum.
Now, I have two Noctua A-14 ULN 140mm fans which I am designating to my Nepton 280L when it comes back from an RMA request. Would it work if I take one of the JetFlo fans and put it right in front of the rad as a pull? Or would it be better to have it as a push?
https://linustechtips.com/topic/281825-a-small-fan-question/
Even if you dump the thread here, it'll get moved regardless.
Play around with it I suppose, experiment with temperatures.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/281825-a-small-fan-question/#findComment-3826709
Are you referring to push/pull?
Don't dump threads into General Discussion and please post in the correct sub-forum.
Moving the thread.
https://linustechtips.com/topic/281825-a-small-fan-question/#findComment-3826714
Moving the thread.
Sorry about that, I wasn't exactly sure if anyone would have responded.
And not exactly, what I want to do is have the noctua fans as a push for the rad (because my case is unable to do a pull config) and then have another fan which sits right infront of the radiator, almost like it was a 420mm radiator except there would be no radiator on the third fan. I just don't know if it would work better to push air out of the case with the third fan, or pull air in
https://linustechtips.com/topic/281825-a-small-fan-question/#findComment-3826720
That would depend on the case and layout of other components.
It would help to list your specs.
https://linustechtips.com/topic/281825-a-small-fan-question/#findComment-3826729
  • CPU
    Intel Core i7 4790k
  • Motherboard
    Asus Sabertooth Z97 Mark 2
  • RAM
    Corsair Vengeance Pro 8GB
  • GPU
    Asus Geforce GTX 970 4GB STRIX
  • Case
    Phanteks Enthoo Pro
  • PSU
    Corsair RM550 80+ Gold Fully Modular PSU
  •    Cooling
    Cooler Master Nepton 280L
https://linustechtips.com/topic/281825-a-small-fan-question/#findComment-3826741
CPUIntel Core i7 4790k
MotherboardAsus Sabertooth Z97 Mark 2
RAM Corsair Vengeance Pro 8GB
GPU Asus Geforce GTX 970 4GB STRIX
Case Phanteks Enthoo Pro
Corsair RM550 80+ Gold Fully Modular PSUCooling
Do you have any other fans that you haven't already mentioned?
https://linustechtips.com/topic/281825-a-small-fan-question/#findComment-3826753
Only the stock fans on the back and front of the case.
Rear/front are stock fans. Fan behind the hdd cage is the Jetflo. NF-A14's and rad at top.
https://linustechtips.com/topic/281825-a-small-fan-question/#findComment-3826820
