so i need 2 120mm fans one for teh front of my case and one for the side il like green LED's if not fro both then just the front one a green LED and the side normal i have $20 max no re baits and would prefer them to be from new egg.
https://linustechtips.com/topic/281748-2-fans-20/
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
https://linustechtips.com/topic/281748-2-fans-20/#findComment-3825804
https://linustechtips.com/topic/281748-2-fans-20/#findComment-3825852
what connection do theres fans use? do they have molex becase i only have molex avabale becase one of my case fans only has a 4 3 pin connecter so i had to use that on my only case fan connectoer on my motherboard
https://linustechtips.com/topic/281748-2-fans-20/#findComment-3826154
Well, you can then get some 4 pin/ 3 pin to molex adapters.
https://linustechtips.com/topic/281748-2-fans-20/#findComment-3826291
