mPCIE Wifi Module
Solved by toggleguy,
I have an EA6500 as my main router, so I was thinking since I usually connect to 5.0GHz I could get better speed that if not higher than 300mbps, better than what I would be getting now.
I still dont think it'l improve it. But i cant say for sure. You may aswell do it if you have some spare time, and your willing to take the small risk of damaging your laptop. Compatibility may also be a problem, so bare that in mind if it doesn't work.
