Hello people of Linus forum. Today i was planing to show off my rig but ran into problems. I installed h105 on my m5a99x evo r2 board with fx8320 cpu. Did it since i wanted to just do some upgrade with 550d case i bought. So long storry short, pc doesnt boot up ( and yesterday it did, only change is the case and h105)
in that 1 second it did boot for more than a sec, i managed to see text abot new cpu or something, then it went black. Now it doesnt beep or anything..just spins fans for2 seconds. So. Could it be there is special way for connecting pump and fans of h105? I have both fans with Y connector on cpu fan slot, pump on cpu opt.
Thank you.
https://linustechtips.com/topic/281257-fx8320-and-h105-problem/
Thank you.
You have the molex plugged in, correct?
Ignore above, the H105 doesn't have a Molex like the H80 does, it sounds like the pump on the H105 is dead if it's cutting out instantly.
CPU: Intel Core i7-4790k @ 4.7 1.3v  with a Corsair H80 w/Dual SP120s - Motherboard: MSI Z97 gaming 5 - RAM: 4x4 G.Skill Ripjaws X @ 1600 - GPU: Dual PowerColour R9 290- SSD: Samsung NVME SM951 256GB-- PSU: Corsair RM 1000  - Case: NZXT H440 Black/red - Keyboard: Coolermaster CM storm Quickfire TK, Cherry MX blues - Mouse: Logitech G502 - Heaphones: Beyerdynamic DT 770 - Monitors: 3x VE248H Eyefinity 1080P -  Phone: iPhone 6S Plus               Please post your specifications in your post, signature or even better, system page on your profile!
https://linustechtips.com/topic/281257-fx8320-and-h105-problem/#findComment-3818771
