Hi guys I recently brought a R9 280. The current monitor I am using is a 720p(shame on me I know) and would like to upgrade and was thinking those 2560*1080 were quite nice. I want to game on my rig can the 280 push that many pixels to play newish games at med - high.
Shifter  :D
https://linustechtips.com/topic/281195-radeon-r9-280/
SHAME ON YOU
-hmm 1440p on med to high, yeah comes close
That is an ultra wide monitor 2560x1080 aka 21:9, alot of game right now are have scaling issues with that resolution so i suggest getting a 1440p monitor ( 2560x1440). It will require a bit more power to run compare to a 2560x1080 but it will save you from the headache you'll get when your game don't support that resolution. In 1440p the 280 will perform well as long as you don't crank the setting up too much.I think keeping it at high setting with aa off should give you a very enjoyable experience.
Mainboard:ROG-STRIX-B360-G-GAMING/Cpu:I5 8400 /Gpu: Galax RTX 2070 /Ram: Corsair Vengeance 16 GB DDR4/ Storage:1TB HDD 2 Corsair SSD PSU : Corsair 550W/Cooling: Silverstone Air Cooler/ / Case : Corsair/Keyboard:Razer Chroma TKL/Mouse:Mionix Castor+Steelseries Qck Mass/Headphone:V Moda M100
Quote me if you when me to reply to something.
https://linustechtips.com/topic/281195-radeon-r9-280/#findComment-3817998
R9 280 is powerful enough to max out every game at 1080p, so ultra wide 1080p monitor shouldn't be an issue. I'm planning to get R9 280 too, but GTX960 convinces me a lot :S
Primary PC
CPU: AMD Ryzen 7 5700X3D | GPU: Zotac RTX 3080Ti 12GB | M/B: Asus ROG Strix X370-F | RAM: Corsair Pro SL 3200MHz 32GB | SSD: WD Black SN7100 1TB / Samsung 870 Evo 1TB | HDD: Seagate EXOS X16 16TB x2 | Power: Corsair RM850e | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung QLED 27" 2K 144Hz VR: Pico 4
Secondary PC
CPU: AMD Ryzen 5 5600 | GPU: Asus RTX 4060 8GB | M/B: Asrock B450M Pro 4 | RAM: HyperX Fury 3200MHz 32GB | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung QLED 24" FHD 144Hz VR: Meta Quest 2
Thanks for reading
https://linustechtips.com/topic/281195-radeon-r9-280/#findComment-3818066
