Stupid vinyl question
PoshBoyGames
I currently have a Pro-ject 1.3 gene connected to some Audio engine a2+ speakers. The integrated amp in the speakers is not so good and vocals are completely wiped out. Can I use a little dot MKII?
Well just looking at the 2 it looks like the desktop speakers are stuck using the integrated amp. You would need some regular speaker wire it seems to power them off of a different amp, and the tube amp you have right now only has a headphone out jack and 2 RCA outputs...i would say no, you would need to get a different amp (something like a home theater amp, you could probably pick one up super cheap at a local goodwill)
Main Rig: | CPU: Intel Core i9-7900x | GPU: Nvidia RTX 2080 Founders | Mobo: Asus ROG Strix X299-E Gaming | RAM: 32GB Corsair Vengeance LPX DDR4 3000 MHz | SSD: Samsung 980 Pro w/Heatsink 1TB & Samsung 960 Pro 1TB | Sound: Parasound ZDAC & Burson Soloist Amp | PSU: Corsair RM850 | Fans: 2x Noctua NF-F12 | Case: Caselabs MAGNUM SMA8 | Headphones: Sennheiser HD 800 | Keyboard: WASD V3 | Mouse: Logitech G502 Lightspeed | Mousepad: Logitech G PowerPlay | CPU Cooler: bequiet! Dark Rock Pro 3 | Primary Monitor: Acer Predator XB272 | Extra Monitors: Samsung Syncmaster PX2370 |
