Start with Home Depot or Lowes.  Take in the screws you have and ask them for help.  They probably won't have the screws in stock, but they should at least be able to tell you the diameter and thread pitch.
Once you have that do a search on Amazon or check Fastenal for what you need.
https://linustechtips.com/topic/279871-push-pull-help/#findComment-3799911
Where do I buy more or get more of those screws?
Hardware stores like Ace will have them in trays so you can buy per screw. It's usually preferred to home improvement stores where you buy as a pack of 20 or something like that.
https://linustechtips.com/topic/279871-push-pull-help/#findComment-3806974
