Hey, so today i overclocked my CPU for the first time. I put it up to 4.4ghz on the stock voltage (stable). So my question is when i change the the "CPU Bus frequency" my "CPU/NB frequency" and "HT Link" values change. So i have to change these values closer to the defaults or just leave them?
Thanks
https://linustechtips.com/topic/279844-fx-8350-overclocking-help/
edit
| CPU: Intel i7 4790K @4.4Ghz  | GPU: Gigabyte GTX 970 G1 Gaming  | CPU COOLING: FRACTAL DESIGN S36 | MOBO: ASUS ROG Maximus Vii HERO | RAM: 16GB G.Skill Ripjaws X @1600MHz  | CASE: Phanteks Enthoo Pro Full Tower | PSU: EVGA SuperNova 850 G2 850W Fully Modular | HDD: 2TB Seagate Barracuda | SSD: 256GB Crucial MX100 | DISPLAY: Dell U2414H | HEADSET: Corsair H2100 Dolby 7.1 Surround |
If your overclock is stable I dont see why youd change it.  When I did mine I had to bump the nb up a little bit but that was all.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
You changed the base clock of your CPU which effects the clocks as you observed. The multiplier is usually a better thing to change but if it's stable then don't mess with it.
R7 2700x | ASUS Strix X470-f | 4x8 Corsair Vengeance RGB Pro | Zotac RTX 2080ti | Lian Li PC-011 Dynamic
2x Xeon X5650 | Supermicro X8DT3-LN4F | 6x4 Micron DDR3 ECC | 4x4TB HDD
