Hi guys im about to order my new pc currently i have a corsair GS800 and need to know if this will power my new pc or if i will need a new power brick. heres what im ordering:
https://secure.scan.co.uk/aspnet/Shop/SavedBasket/SavedBaskets.aspx?Id=ea906235-d688-4de3-89af-a0ddcfde9340#BasketDetails
aswell as http://www.scan.co.uk/products/intel-quad-core-i7-4790k-processor-plus-msi-z97-gaming-5-motherboard-bundle
Please let me know. I have one in my basket in case but im hoping my old one is enough, thank you
https://linustechtips.com/topic/279706-help-asap-please/
Hi,
I'm sorry, we can't view your shopping cart. Be sure to use http://pcpartpicker.com/ to put together your part list, so we can have a look. ;)
Chances are your GS800 will be enough for the system.
who cares...
https://linustechtips.com/topic/279706-help-asap-please/#findComment-3797183
I almost guarantee 800 Watts will be WAY more than you will need, although i can't see what is in your list...You would need the most power hungry CPU (say a 9590 AMD for example) and 2 top of the line graphics cards to needing that much power. Many people have a skewed look at PC building from these YouTube videos where they will build a system with 2 graphics cards and put in a 1200 Watt power supply which is just insane overkill...you would need that much for maybe 4 way SLI, for most people a nice high end CPU and high end Graphics card will only need around 400-500 watts.
Hope this helps,
Also it seems many people do not know about this handy website that you can type in exactly what you have and itll spit out a pretty accurate number of what you will need..
http://www.extreme.outervision.com/PSUEngine
Cheers!
Main Rig: | CPU: Intel Core i9-7900x | GPU: Nvidia RTX 2080 Founders | Mobo: Asus ROG Strix X299-E Gaming | RAM: 32GB Corsair Vengeance LPX DDR4 3000 MHz | SSD: Samsung 980 Pro w/Heatsink 1TB & Samsung 960 Pro 1TB | Sound: Parasound ZDAC & Burson Soloist Amp | PSU: Corsair RM850 | Fans: 2x Noctua NF-F12 | Case: Caselabs MAGNUM SMA8 | Headphones: Sennheiser HD 800 | Keyboard: WASD V3 | Mouse: Logitech G502 Lightspeed | Mousepad: Logitech G PowerPlay | CPU Cooler: bequiet! Dark Rock Pro 3 | Primary Monitor: Acer Predator XB272 | Extra Monitors: Samsung Syncmaster PX2370 |
https://linustechtips.com/topic/279706-help-asap-please/#findComment-3801043
